Maintenance of a MDT like FL series freightliner will basically consist of changing the oil and lubing the chassis. If you have an air dryer on the air system, the cartridge will need to be changed, but not as often as the oil. Longer term probably transmission and rear end lube changes, radiator flushes. Nothing real radical. The oil change intervals will probably be longer than on the dodge/cummins combo, it will depend on the engine you end up with. Getting a nice MDT toter will probably be a bit pricier than a toter built off of a class 8 truck, but might be better suited to your needs. Especially if the significant other is going to be driving and might be intimidated by the size of a class 8 tractor. Also, if you're going to be using the power unit for transportation when the rv is parked, a MDT will be easier than a class 8. It won't be as easy as the dodge, but you're going to have to make some sacrifices to pull that big trailer.
