What's a "hotshot" ?
Cold and O/D
Vibration, tires?
huh?
http://coffeewithJesus. homestead.com/web1.html 89 1-ton, Amsoil System 3000 5-30,K&N air filter, cleaned-up exhaust, Dynomax straight-thru, rebuilt pump, 12cm wastegated turbo (not installed), thermostatically controlled twin 14" Permacool electric fans, intercooler (installed, not plumbed), modified 518 OD transmission, Gear vendors OD controler, R-134 refrigernt, louvered front fenders, 93 aftermarket smoothie grille, new Dupont Chroma-colr black, black-and-red rubber rubstrip, Cummins badges, black headlights; 78 35'Avion, 93 Lance 900 slide in with generator and power jacks. Jesus saves!
"Hotshot", as pertaining to Trucks with Cummins engines would be someone or a company who specializes in fast, all hours of the day or night pick up and delivery of equipment/material etc. for a fee. bg
White 99 3500, QC, 3:55, auto. most options except leather, Line-X bed liner, fiberglass running boards Rancho 9000s, bug shield and window vents, black vented 5th wheel tailgate, 100 gal. aux. fuel tank.
Many medium duty trucks are used for hot shots also... ...
They're basically smaller version tractor-trailers. Like the duallys with the big flat bed gooseneck trailers that are being used commercially... .....
When they come for my guns they can have them, BULLETS FIRST!!
<<>>Charles Pyatt<<>
*Protect your rights given by our constitution*
Ditto on the above. Read my sig and go to the homepage. I run 3,200-3,800 miles a week on the 92 alone. We are regulated just like a semi. Class "A" cdl, log books, the whole garbeled mess. Yes theres $$$$$ in it but only running long hrs and bustin our butts. But still better than 50K per yr job. Mike
92 Std cab. LE. 215 P-pump reman cummins motor. NV 4500 5 speed, 3. 54, 105 gal Aux tank in bed. Borgeson shaft, Banks Power pack. 12cm Hot end housing w/wastegate. 4" Exh, Pyro & boost guage, oil temp guage. E-brake. Galaxy DX99V, Used as a Hotshot/express Reg. at 36,000 lbs in 48 states. Custom built DOT approved Sleeper unit. & Texas Star 400 http://hometown. aol.com/hotshothauler/myhomepage/business.html 2000, Air brakes on truck & trailer. 19,000 miles todate. DOT custom built sleeper unit. pulling a 40' G/N flatbed
2000 FL-70 Pulling a 48' low boy.
VERY interesting. Since my stroke, I can't work around large groups of people (I taught!), but I do quite well all by myself!
http://coffeewithJesus. homestead.com/web1.html 89 1-ton, Amsoil System 3000 5-30,K&N air filter, cleaned-up exhaust, Dynomax straight-thru, rebuilt pump, thermostatically controlled twin 14" Permacool electric fans, intercooler), modified 518 OD transmission, Gear vendors OD controler, R-134 refrigernt, louvered front fenders, 93 aftermarket smoothie grille, new Dupont Chroma-colr black, black-and-red rubber rubstrip, black headlights; 78 35'Avion, 93 Lance 900 slide in with generator and power jacks. To see my truck, CLICK on: <A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1169022&a=10097213
" TARGET=_blank>http://albums.photopoint.com/j/AlbumIndex?u=1169022&a=10097213
</A>
Jesus saves!
