Gary,
I feel that the updates have vastly improved the VP44. When I lost mine I only had 30,000 miles on my truck. I probably could have went a little longer before I changed it out, but knowing something isn't right eats me up like a cancer. I noticed a slight surging pulling heavy, got the CEL & P0216, and then got the dead peddle twice. This all happened on one trip back from Oregon. Since I had very low miles I felt the best thing was to have my pump rebuilt. I took it into Diamond Diesel in West Sac. and they sent it into their main rebuild facility, in the bay area. They sent me back a report that the main cause of the failure was the brass advance piston sleeve, which they had an update to a steel sleeve, which I think you had the same thing fail in yours. But they also gave me an itemized list of all the updates my pump needed. My serial number VP44 needed a shaft and front support bearing update, a diaphram update, along with a FPCM update. Parts alone would have cost $1400 and I could buy a reman. off the shelf for $1093 that had all the updates already in it. I asked Margaret, who I've dealt with for years and trust, what was the failure rate on these rebuilds with all the updates, and she said they have had very few failures on the current pumps with all the updates. My truck was a late 2002 built in Mexico. I feel allot of the P0216 timing failures were due to the rapid wear of the brass advance piston sleeve on the VP44's in the 2001 & 2002's. Correct me if I'm wrong but it was my understanding that the early VP44's in the 98. 5 to 2000 trucks had a steel advance sleeve and somewhere in the 2001 and 2002 build of these trucks, Bosch started using the brass sleeve, which proved to be a bad idea and they went back to the steel sleeve.
I used stanadyne performance formula every tank full since the truck was new and I had a fuel pressure gauge in the truck since it was 3 months old. I never let the fuel pressure drop below 5 psi on a heavy pull. I did go through the Carter lift pump growing pains. Never satisfied with the low pressures, 10 psi. at idle and would drop to 5 psi. on a heavy pull. Put a new pump on the engine and same thing. I then relocated the pump to the frame rail with the Vulcan big lines kit and got good pressures but then got cavitation issues and erratic pressures. I changed the Carter on the frame rail again and it was fine for a short time but same thing again. I finally installed an AirDog FP-80 on my truck when it had about 20,000 miles on it. This gave me 15 to 16 psi at idle and never lower than 12 psi. on a long pull and pushing it hard. !0,000 miles later was when my VP44 started acting up. The point here is I always used a lubricity additive every tank and always had a positive fuel supply to my VP44 and it was the engineering error by Bosch to make the change to the brass advance piston sleeve.
My truck was still under the 7/70,000 warranty from Dodge at that time, but I already had an Edge EZ, a turn-buckle on the HY35, and the AirDog fuel supply pump. I couldn't do that and feel good about it. What was one of the first things I read on the TDR ? Once you modify "YOU ARE YOUR OWN WARRANTY STATION".
I guess I added more than my $. 02 worth to Gary's thread, so I apologize for being long winded here.
Hey Gary do you miss Vacaville/Allendale much ? Or are you just like all the other Oregonians now, just another transplanted Californian that bad mouths Californians. Sorry for the pun, I've got several relatives up there that fall into that category. Anyways I wish you well and take care.
Regards, Mike.
