Just ordered my fourth TIPM. One of the previous was actually not bad but dealer replace under warranty. I used to use a britebox and I figured that was the culprit. Now I have the Controlfreak that runs the head lights off their won circuit directly from the battery. As of now, I have only 2 potential causes I can think of: 1), is the Painless accessory fuse box. All my accessories run off this and it is powered directly from the battery. This gets turned on by the horn circuit in the TIPM, 2): Gauge lights, I have 8 gauges that themselves get power from the above mentioned painless fused circuit. But the back lighting is from the factory light switch and dimmer circuit. I think this is the problem. Also, the dimmer recently started to flicker on the most dimmed setting (where I run it at night). Now TIPM is doing it's death throws. So is it the gauge back lights, a bad dimmer/rheostat (perhaps cause by the extra back-lights) or something else? Any thoughts? BTW I also have a TIPM saver for trailer lights so that's not it. At several hundred dollars a pop, this is getting expensive.
