Vaughn MacKenzie
The mechanical oil pressure on my ETH truck reads:
Cold idle = 75psi
Warm idle = 32-35psi
Cold cruising = 90psi
Warm cruising = 65psi
This is reading downstream of the filter/oil pump at a port in the side of the engine just below the ECM box. Running Amsoil 15W40 HDD oil.
Vaughn
'01 2500 QC Shortbed 2wd, 6-speed, 3. 54LSD, Cab & Fog lamps, Camper & Tow Pkg.
BOMBed: RV injectors, PS Boost module, Amsoil air filter, straightpiped exh. , Aeroquip 3/8" fuel line w/tank mounted lift pump, AutoMeter Sport Comp gauges, Line-X'd, Amber turn signal conversion.
Mildly BOMBed Performance: 0-60 @ 10. 0 sec. ,
40-60 @ 5. 5 sec. ,
0-100 @ 24 sec.
Cold idle = 75psi
Vaughn
40-60 @ 5. 5 sec. ,
0-100 @ 24 sec.
