Just installed an Isspro EV series 0-80 psi Electric Gauge, plumbed into the 1/8" plug on top of the oil filter housing.
Cold, at idle 60psi, tap the throttle and it pegs the 80 Pound gauge. When warm, after an 80 mph freeway cruise, idle @20psi, dips to @10 when letting out the clutch with no throttle. Still pegs 80 psi gauge @ 2000 rpm.
Gauge seems to be very responsive, and "spikes" with just a tap on the throttle. I have rechecked all my wiring and everything is good there.
What's up with that, doesn't seem right. Am running Amsoil filter and oil, less than 1000 miles on change. Is there a bypass valve somewhere that may be stuck shut, or possibly leaking when warm? Is 80+ psi at rpm ok? If so, guess I'll call Isspro and see if they'll let me trade it for a 100 psi gauge :eeek:
What do you guys think?
