What's The Best MPG You Have Ever Gotten????
Sky-Biz
Whiners! THEY created the monster..
Just completed a 2643 mile round trip, Atlanta Georgia to Ontario Canada.
Interstate speed 75 MPH with cruse control on 90% of the time.
Approx 300-400 miles of city driving.
Truck only with approx 900-1000 lbs. of gear... passanger/driver.
Speed and mileage check with GPS... dead on with truck gauges.
Average mileage for trip. . 19. 7 MPG
Gary
01' 2500 - QC/SB, ISB w/Auto, 4X4, 3. 54 LSD, Solid White - Westin Bars, A. R. E. Cap, Bug/Vent Sheilds, K&N Air Filter, Autometer Ultralites Boost/EGT/Trans, Custom 4" Exhaust.
[*]TU Member
[*]NRA Member
[This message has been edited by RollCast (edited 12-03-2000). ]
Originally posted by sdalton:
rich m, I know you drive a cummins, from your past posts. Please indicate in your signatures what you drive. Thanks
H'yar 'tis----also, average mpg (urban mix driving) been a real solid 15. 5-16. 5 with verrrrry gradual improvement as break-in (and BOMBing) progresses
mildly BOMBed 98. 4 1B7KF23D4WJxxxxxx-- BD's #5 plate and 210HP injectors--BD Brake and the associated transmission bomb goodies (except for TC,currently), 4" open exhaust (short),Psychotty, camper shell, Warn front receiver, G159Unisteels on Rickson 19. 5's. . CD player is bone stock, so are the seats. PrimeLoc, also remote spin-on filter for the auto trans... Pyro,Boost and Trans temp from Isspro,
Westin nerf rails(black),
bent welding rod to hang celphone on dashboard...
240HP on Dynojet from 75-105mph drumspeed.
If the wife drives it runs 23 to 27 mpg. If I drive it runs 20 to 24. One would think that should tell me something... I figure no tickets musta been a safe trip... Pulling loads it will vary from 12 to 16 depending on several things. A full fuel load and my big hinney will put the truck @ 8800 lbs. Biggest help is the overdrive splitter to keep the rpm's down but don't get caught lugging which I do now and then. The temps really rise quick when ya do that but the click of a button will bring those back into control quickly with the increase of some RPM meaning more air & boost for the turbo...
1997 3500 SLT, Ext cab, 5spd, TST #11, GV Aux Trans, BD exhaust, Kelderman Air Ride, 60 Gallon fuel tank, Clifford Security, Reese 20k 4way 5th wheel hitch, Boost/EGT gauges, K&N air filter, Rancho RS9000 shocks, Brush Guard, DZee full length running boards.
Going to work,about 145 miles round trip on my last tank got 20. 8 that includes city and country driving. Started out at 17 but it has got better with more miles about 27000 now. Engine,transmission,rear diff on Amsoil. Still have to do front diff. and transfer case. Last few tannks have been 20+ but with an occasional 19+ in there. 65-70 on highway.
2000 Dodge 4x4 Quad Cab SWB 5-SP
'97 Ram 3500, 5 speed 4WD- Best I ever got was 17 on the interstate at 65 mph/ 2200 rpm. (3:54 gears). Usually get 14 to 15 all the time whether I'm empty or pulling a 20' gooseneck with 3000#. Better since installing the TST torque plate- used to get 12. 5 to 14 before, plus TONS more power now!
24. 2 mpg. Buffalo NY to Dayton OH. 45 degrees. 65-70 mph. Since the day I bought it new in '95, the Cummins/Dodge has averaged 20. 2 mpg. I record every fillup and enter it in my computer to track for problems. It's helped more than once.
'95 2500 SLT ClubCab, automatic, 3. 54 LSD
For the total month of September.
Total average came out to 21. 05 mpg.
Oh yaa one trip or tank full is not an accurat way too figure mileage. Do at least a months worth of driving.
On a trip from Ft Collins CO to Calhan CO and back got 250 miles from 10. 9 gal of diesel. Same pump, same station. 92 D350 club cab auto 3. 55 gears, 70-80 mph. No strong winds or anything unusual. My 93 W350 club cab 5 speed 4. 10 got 19 or so on a trip to Denver at 65. Never taken it on a long trip. After I install a splitter, i expect to do much better on hwy.
Daniel's current truck: 1993 W350 club cab, 5 speed, treadplate aluminum flatbed, 4. 10 rear end, straight pipes, K&N, "slightly" tweaked pump. ISSPRO color coded pyrometer and 50psi boost guage. NRA Life Member (since age 12) and d@mned proud of it. IRBCTS.
My Truck: Stock for now, 96, 2500, 4x4, auto, 3. 55's, stock size tires 245/75/16 (way too small but good in the snow).
All time best is 21. 65. That was traveling at speed of 55 - 60. Average Intersate MPG are around 19. 5 traveling 70-75.
Just got back from a 352 trip, 40 miles were stop and go city driving, air temp averaged 35 degrees, had my tonneau cover on, synthetic in front and rear end only, and DCI+ in the fuel tank, the trip was 19. 8 mpg. I was pretty happy with this being winter fuel in our area.
I hope after some bombing to get a little better mileage, but I really can't complain. The best my 1500, Dodge, 360, 4x4, auto ever got was 14. 65.
Ryan
Last 20k average is 19. 4. One tank high was 23. 8mpg. Winter fuel and cold has gotten last 3500 miles down to 18. 2. Lowest ever was pulling boat full of stuff with a 30 mph headwind, got 15. 9. Mileage and power improved to about 40k.
99 2500 QC 4X4 AUTO SB 24V LARAMIE SLT 3. 5 LSD 285-75-16'S
I once saw 99 MPG (on the computer) going down a long freeway off ramp with the engine at idle. Does that count?
[This message has been edited by red1ton (edited 01-15-2001). ]
Ok I have nothing to gain either here is the reality of it. Bad Bad Mileage.
Hope you can read this.
Fuel Flow For 1999 Dodge Quade Cab Diesel
#DIV/0!
Date Beginning Odometer Ending Odometer Miles Traveled Gallons of Fuel Miles per Gallon
15527
9/3/00 15527 16074 547 51. 089 10. 70680577 Towing
9/10/00 16074 16266 192 13. 848 13. 86481802 City
9/17/00 16266 16535 269 24. 331 11. 05585467 Towing/ City WO/T
9/20/00 16535 16859 324 26. 335 12. 3030188 Towing/ City WO/T
9/29/00 16859 17185 326 22. 993 14. 17822816 Highway
10/6/00 17185 17451 266 16. 038 16. 58560918 Highway
10/21/00 17451 17772 321 22. 7336 14. 12006897 Highway
11/7/00 17772 18151 379 25. 764 14. 71044869 Highway
11/17/00 18151 18504 353 25. 28 13. 96360759 Highway
11/30/00 18504 18828 324 23. 064 14. 04786681 Highway
12/11/00 18828 19171 343 24. 119 14. 22115345 Highway
12/22/00 19171 19554 383 26. 924 14. 22522656 Highway
12/31/00 19554 19846 292 20. 253 14. 41761714 Highway/City
1/5/01 19846 20022 176 13. 014 13. 52389734 Highway/City
1/16/01 20022 20400 378 25. 768 14. 66935734 Highway/City
20400 -20400 #DIV/0!
0 0 #DIV/0!
0 0 #DIV/0!
0 0 #DIV/0!
0 0 #DIV/0!
0 0 #DIV/0!
0 0 #DIV/0!
Total 0 sum 361. 5536 #VALUE!
Best was with my 94 at 22mpg auto,4:10s at 75 mph from one side of the state to the other. Best with my 99 was 19. 9mpg auto,3:55s. With this new one I'm still trying to figure it out!! #ad
Pete
01. 5 Loooaded up!!!!!
The best milage i have ever got was 23. 6 MPG on a 160 + mile trip after removing the cat & adding a 1 chamber flowmaster muffler. (3. 5 rear 65-75 mph summer 80 + deg. )normal city 17-19 freeway 18-21
95 club cab auto 2wd +GENO'S COMBO GAUGE + SONY 10 disc + RCA 9" tv/vcr + 1 CHAMBER FLOWMASTER +LOST cat + silencer ring + slid stock plate & k&N so far... ! member of the SETDR
Richard G. That's really terrible milage. You need to see about checking the turbo hoses. If it isnt them then you might make an appointment with the dealer. If no satisfaction is had there then take it to a Cummins service center. They will look the whole thing over, and probably find the problem.
Y2K, 2500, 4x2, QC, 3. 54 LSD, Auto, patriot blue. K&N, silencer ring put back in. 14000 miles as of 1-05-01. best milage:28. 5 mpg. transmission reflashed
I can get 22 hwy, unloaded, @ 65... this with a 99 quadcab, 4:10, auto 4x4, and 255s for tires. Lately, getting 16-17 combined, and seems to be maybe cause of the winterized diesel.
My best mpg was 25. 03 @ about 70 MPH. This was all on Interstate 10 from Eloy, AZ to Tucson, to Phoenix, back to Tucson and back to Eloy, filled at same pump both fillups. Usually runs about 20 everyday drivin'. That's my story and I'm stickin' to it!
Rob. .
'94 2500SLT, LB, 3. 54, Automatic, TransGo Shift Kit, DunRite Convertor, TST HD Clutch Pak, TST #5 Fuel Plate, TST AFC Spring Kit, 16 sq. cm turbine housing, PacBrake, AutoLoc, EGT Gage, Mag-Hytec Diff Cover & transmission Pan, DeeZee Chrome Full Length Running Boards, Northwest Custom Rear Flaps, Vent Shades,. Pull 35' HitchHiker Premier WideBody 5th Whl (13,850+ lbs). 155,768 miles as of 1-6-01 Full Time RV'ers, Portsmouth, Ohio is "home".
I had a 100 mile stint in the snow at 50-55mph"27. 9". But average about 21-23 empty. Nothing lower than 12 pulling fifthwheel and boat.
95 Dodge 2500 Luverne grill guard,headache rack,running boards and Amzoiled. Soon to be mildly bombed. 84 Dodge d-150, 318 Hooker headers,Edelbrok intake,mallory ignition,Carter Afb,Accel coil,and Custom dual exhaust. Boat,fifthwheel,motorcycles,and shop,job to support toys. Yuck...
Best ever in 40,000 miles was 17. 2 once on the interstate at 65 empty. Usually get 15. 5 average driving.
'97 Dodge 3500, 3:54, 5 speed.
