What's your axle ratio?
Stronger tires?
Towing after reflash
Was involved in a discussion over in the GM Duramax group, and a fella was bragging about how much better his new Duramax/Allison setup pulls his 19,000 trailer than his late model Dodge/Cummins - tho' he IS happier with the fuel economy from the Dodge.
Turns out, the Dodge has a 3. 55 axle ratio vs a 3. 73 in the GM. I responded that the Dodge was SERIOUSLY out of its towing capability with the 3. 55 pulling 19,000, and that 4. 10's would give FAR better pulling capability - in fact, not sure that the Dodge is even RATED to pull that heavy a load!
SO - you guys towing loads well over 10,000 lbs. , what axle ratios do YOU use, and are you satisfied with it - especially when pulling in the hills? If you DO use 4. 10's, what sort of fuel mileage are you getting empty/loaded? Primarily interested in stock or near stock engines...
http://community. webshots.com/user/davison71 Early '91 250, 727 AT, 307 rear... Banks Stinger exhaust, intercooler... US Gear OD... MORE than a match for every new PS Ford encountered so far...
Ummmmm... My 95 2500 was routinely worked at around 24,000 - 25,000lbs. I pulled a 40' 3-axle goose enclosed race trailer. At that weight, with a/c and cruise set at 70, I averaged 15. 2mpg on flat ground... it was a 5 speed with 3:54 axle, hot pump and open exhaust. It would climb without problem.
97 2500 CC 4x4 3. 54 5spd, Green, #12 plate slid all the way forward, 4inch open exhaust, 235/85 Michelins, RS 9000's, PrimeLoc, Red Tops, TDR cloisonae grill badge!
Okay, lets see. I have 4:10's and the 6 speed and empty with little miles on the truck(less than 3,000 miles) I'm getting 15. 3 mpg in town and 17 mpg on the open road(not interstate). Towing a trailer around 13 or 14 thousand pounds I'm getting 13. 8 mpg. Trucks tow rating from Dodge is 14,300 lbs. with a GCVWR of 21,500 lbs. Pete
I pull big loads from time to time and have 3. 54s and 5 sp. 275hp injectors and TST PM2. If I go 70 mph with the load, miles per gallon are in the 11 range. Wish it was better, but it's not. I have all the power I need, though, so I'm not complaining.
99 3500 QC 4X4 5sp 3. 54 K&N air filter, DiPricol gauges, 275 hp injectors, Pacbrake, Westin nerfs, GN hitch, Tekonsha Brake controller, Mopar seat covers, Husky mats, silencer ring removed, Draw-tite front receiver, Rancho 9000's
With a '00 3500QC 4. 10 with a 6 speed, stock engine, 20,000 lbs GCW, I am very satisfied with the power. I did have a VA box on the truck, but took it off a couple of months ago and haven't gone to the "trouble" to put it back on since I have been hauling the Lance. Mileage runs 10-12 towing and 16-18 solo. When hauling the Lance MPG runs between towing and solo.
Bill
Y2K 3500QC, 6 Speed, 4. 10, SLT+, Camper & Tow Pkg. , Westin Chrome Nerf Bars, Mopar Flaps, Reese 20K Hitch, EGT & Boost Gauges, RPM 45 Gallon Aux. Fuel Tank, Highway Products 5th Wheel Toolbox, ECM Controlled PacBrake, Painless Wiring Kit, Mag-Hytec Diff. Cover, Rancho 9000, Air Lift 5000 Air Bags, TOYS: '97 Hitchhiker II 31' 5th Wheel, 2 slideouts, 19,750 GCW, '94 Lance 990 11' 3" Slide-In Camper, Torque-Lift Camper Tiedowns
3. 54 and satisfied. avg. 21-23 unloaded. 12 pulling 30 ft 5er. 11 or a little better loaded with green cut firewood. 2 and a half chourd. I usually pull 65-70 mph on the freeway if road is good.
2001 quadcab slt 2500 HO 6spd. LWB,2wd,dk garnett red, trailer tow package,camper special, anti spin 3. 54 axle, speed liner,oversized stainless steel chicken slide,66 gallon in bed aux. tank,K&N air filter,Reese 20k hitch, Terry 2000 EX 30ft. double slide 5er, 2000 20ft gooseneck for haulin jeep, firewood and huntin stuff. 5X12 tagalong for haulin the 4 wheeler. Okie Newton
