What's your "SCALED" weight?
First pull with me kit
Turnball system
It appears some are guessing what the total weight of their rig is when towing. How many have put the combination on a scale to see actual weights:
My total weight with my truck (see signature) and 28' Jayco 5ver (Model 263) is 15,720 lbs. That is loaded with all fluids and stuff needed.
Steer Axle: 4380 lbs
Drive Axle: 4140 lbs
5ver Axle: 7200 lbs Trailer GVW is 10000 lbs.
Weigh those rigs and show what your actual weights you are pulling.
99 QC/LB,ISB w/auto,4x4, 3. 54, VDO (boost, pyro) Westin SS Nerf Bars and Grille Guard, Delta tool box, CP Industries pivoting 5th wheel, Louverd 5th wheel tail gate, K&N, VA CPC, BD/VB, Torq-loc, and Exhaust Brake. 54405 miles (1/12/01)
Ordered "01" ETH/DEE 12/11/00 Due date:2/10/01
00 28' Jayco 5th Wheel, 86 "Classic 16" Alumacraft, 00 Honda Rancher
Don't remember my exact axle weight but my total for truck and 5er is 19,600 lbs
Mike Clay
2001 HO,6 speed QC,2500,4x4Dark Garnet Red,ISSPRO E&B gauges on A Pillar, Rhino Nerf Steps Lit, Series 3000 brush & grill guard, NW Custom rocker panels, Jacobs E-brake, all options except leather, Reese 20k hitch. Towing a 30' Gulf Stream Sea Hawk 5th Wheel triple slide. The Mule
I had weighed my '96 2500, 20500#, trailer weighed 13200. That is why I upgraded to the 3500ETH, I didn't weigh this one yet, but should come in just under the gcwr of 21500. Trailer definately under the 14300 they spec'ed.
Larry
33,000 and some change. This was on a Indiana DOT scale. They were the ones kept in the car, and analog not digital. This was weighed in the driveway before a 200 mile trip to deliver it. It was a Great Plains 30' Drill on a 36' gooseneck. The weight wasnt a problem due to my dad dating the DOT officer. #ad
1996 2500, 4x4, 5 speed
-- email address removed -- Great Lakes TDR
PURDUE STUDENT
GO BOILERS
Scaled Weights:
Truck 6720
Trailer 8880
Truck w/trailer frt 3640
Truck w/trailer rear 4960
Gross 15600
01 2500,SB, Club Cab, 5spd,3. 54 LS, Bright White, Camel Leather. 01 Sunnybrook 27' 5ver--All Stock
Scaled weight:
Steer Axle 4900 lbs
Drive Axle 6920 lbs
Trailer 1680 lbs
Truck weighed 11,820 lbs
Gross 13,500 lbs
This weight has been on the truck for the last 4 months and 12,000 miles and my "Beefed" Camper package works great. The factory overloads are Bye Bye.
2K Dodge 3500,4x4,SLT,Quad Cab,PR4 Red,Auto Trans,3. 54's,Anti-Spin Axle,Trailer TowPack,3 Piece Auto Ventshade Hood Protector,"BEEFED" up Factory Camper Pack{No Airbags},Factory Fogs,Rear Slider,Rancho 9000's,Rhino Spray In Liner,Smitty Built Nerf Bars,Alpine 60x4 Watt CD Player,Lance Cabover Camper,BD Plug n Power,K&N w/Modifed Stock Box,Amsoil 15w40,EGT Guage,And Enjoying The Ride.
2K Dodge 2500 SLT RC LB PB3 Blue
99 Dodge 1500 SLT/Sport RC SB Solor Yellow {Her Truck}
[This message has been edited by Crazy Horse (edited 01-20-2001). ]
Are you fellows aware that vehicle scales have over an 80% failure rate on Inspection. I certify scale for the state of New York. I put my 3500 an a scale I inspected the day before so I know my gross with a 945 Lance truck camper wet is 12400. Do not believe most scale unless you see a recent inspection state seal attached.
My combined weight varies but averages between 18,500# and just short of 20,000#. Alpinlite truck camper and 16' cargo trailer on a new ETH 3500. The truck is loaded that way 100% of the time.
1995 2500 5 spd US Gear 2 speed,PackBrake, bombed,big turbo, injectors CUMMINS POWER!!. 2001 ETH 3500 PackBrake, gagues,otherwise stock. 1972 "1066" International Harvester 414 ci diesel pulling tractor, big pump,turbo and injectors. Alcohol injection,BINDER POWER!! .
GONZO
17,340 #, 28' fiver, ceder creek.combined weight.
2001. 5 2500 4x4 6 speed white quad cab. k&n air filter, getting ready to add chip and remove muffler. 28'fiver(love to pull it and leave the phords behind!
Well, I didn't have my boat with me, but I did hit the scales at work today. Weights were measured with a full tank of gas, fiberglass shell, some tools and me (220 lbs. )
Front = 4060 lbs
Rear = 3000 lbs
Total = 7060 lbs
Someday I'll hook up the boat trailer and see what the grand total is... ... #ad
Scott Collins
'98 Ram 2500 4x4 12 Valve Cummins. Slightly BOMBed! #ad
Renton, WA
[This message has been edited by Scollins (edited 01-24-2001). ]
Our rig grossed 21,760 at Flying J scales somewhere in Texas (don't remember town)
Rob. .
'94 2500SLT, LB, 3. 54, Automatic, TransGo Shift Kit, DunRite Convertor, TST HD Clutch Pak, TST #5 Fuel Plate, TST AFC Spring Kit, 16 sq. cm turbine housing, PacBrake, AutoLoc, EGT Gage, Mag-Hytec Diff Cover & transmission Pan, DeeZee Chrome Full Length Running Boards, Northwest Custom Rear Flaps, Vent Shades,. Pull 35' HitchHiker Premier WideBody 5th Whl (13,850+ lbs). 155,768 miles as of 1-6-01 Full Time RV'ers, Portsmouth, Ohio is "home".
Runaway:
Had my truck weighed on a "Cat" Scale
in Indiana the first of the month.
Truck Weight: 6,820 pounds
(That was with full fuel
and me in it. )
Red '96 4x4 2500 Auto 3. 54, TST #5, Major Pump Mods(By "Scheid Diesel") 370 Diamond B Injectors, Gov. Spring kit, AFC Spring kit, Banks Exhaust, Prime Loc, Cummins Chrome Kit, Pro-Torque Converter, BD Valve Body, BD Pressure Loc, Isspro Gauges, Sendel 16" Alum Wheels w/ 33" BFGs
I recently purchased a 5th wheel with an advertised total weight of 7700# and a pin weight of 1600#. I pulled it onto my friendly neighborhood gravel yard scales to see what it really weighed. I know the truck itself is about 7100# (with me). Anyway, with the trailer (completely empty), the truck weight was 9600# and the trailer (still connected to the truck) was 7000#. This seems to imply that the pin weight of the trailer is 2500# and the total trailer weight is 9500#. I don't see how it could be that far off from the advertised weight, especially the pin weight. I'm over both the pathetically low tow rating of 9000# (which still amazes and frustrates me) and the equally pathetically low GCVW of 16000#.
2k 3500, QC, 4x4, SLT+, auto, 3. 55s, 4" exhaust w/muffler, 14sq. cm Holset turbine housing, Westach gauges (EGT, Boost, transmission)
Kevin, that gravel pit scale --when was it last certified? May want to go to your local truck stop and weigh on one of those "CAT" scales. Also, was the scale you used section'd. Meaning; were you able to put the front axle on one section, the drivers on another and then the trailer wheels on the third section?
Runaway, I don't know when the scales were certified and it is not sectioned. There is one plate that I can fit either the truck or the railer on. After weighing it, I may run by a truck scale and see what it says. The gravel yard is nice because it's close and free. I have read that trailers are heavier than the published weight, but this seems too far off.
Weighed on a private woodproducts scale with myself and co-pilot. 18,580# total. Room on scales for both units. The 100gal water tank water tank was empty. The 60 gal fuel tank was full. So if I fill the water tank etc I will need to add 1000+lbs.
Bert
2001. 5,3500 QC 4x4, HO/6spd,limited slip,BD brake,60 gal Aero tank.
Weight - lbs.
Steer Drive Trailer Gross
4,040 4,380 6,600 15,020
Weighed on CAT scale at Pilot Truck Stop, Springdale, Arkansas.
Trailer was dry.
