Wheel adapters
Cat power??
Cool Stuff/Sites
Does anyone know where I can find adapters to install 22. 5” rims on a ¾ T Ram.
99 2500 QC/LB 4X4, ProTorque TC, BD Valve Body,
TST 275hp injectors, PowerMax1 & VA CPC.
60 Gal. Aerotank, Geno's Combo Gage, Espar Heater,
HX40 Turbo ordered
I've been looking around for the same thing (except I want 19. 5" wheels). The only thing I've found is for the duallies only (check issue 28). Everytime I go down this road, it leads to Rickson's.
Sorry. Post back if you find something.
1999 24V, NV4500HD, QC, 4x4, 3. 54, 8' Bed w/ Rhino Lining, 285/75R16s on 16x8 Eagles, Glasstite high topper
Animal, Rickson will make you a set of 22. 5's with the original bolt pattern so you won't need an adaptor. I don't know if this is limited to only dually style of if it includes singles, but Rickson is the way to go. I have considered it myself but I spent a ton on Dual Designs package a few years ago so I'm stuck with those for awhile.
98. 5 3500 QC 4x4, Driftwood/Mist Grey, 5 spd, 3. 54, 19. 5 Alcoa's, 245/70-19. 5 Michelin's, Ranchhand front bumper, Ranchhand rear bumper, Ranchhand toolbox, "Scotty Air", TST PowerMax2, Autometer Gauges, Centerforce clutch, Upgraded fuel lines (JRE and Aeroquip), MagHytec Diff Cover, PacBrake
Jeff,
I already have the rims so I need an adapter. I got them cheap and there Aluminum, so it looks like I'll have to make my own adapters if i can't find some.
Animal, call Dual Designs and see if they will sell you a set of adaptors only, as long as the bolt pattern is the same. Dual Designs uses the Alcoa's with the larger bolt pattern so it requires an adaptor. If they won't do it, you can talk to a good machine shop, although it will probably cost more.
This may sound a bit off track but Vette Brakes (http://www.vettebrakes.com) makes adapters for anything (85 vette wheels on my girlfriends 78 Z-28). Reasonable prices and good quality, give them a call and let us know what you end up doing.
'94 3500 4x4, 196,000 miles, Auto w/shift kit,3. 54 Gears, TST #5 plate, 235-85-16s, Rancho 9000s w/remote, Isspro gauges inplace of cupholder & Amsoil Bumper to Bumper. NRA member.
