Does anyone know the skf part # for a 2wd 03 front wheel bearing assy. . Already have the # for a 4wd assy. . Thanks
sp_longhorn said:Does anyone know if the 4wd hub would work other thank it has a hole for the axle??
rbattelle said:That might be the case. The parts manual doesn't seem to distinguish between 4wd bearings and 2wd bearings.
Ryan
dezeldog said:Ryan do you think that the 2wd and 4wd bearings are interchangable. I was under the impression that you had to buy the whole hub/bearing assembly for the 2wd. TIA
rbattelle said:I really don't know. As far as I can tell, the parts manual makes no distinction between the 4wd and 2wd bearing assemblies. If someone with a 2wd would take a picture of the bearing we could confirm.
Ryan
mr. wilson said:Are you replacing just the bearing or are you replacing the whole hub assembly?
