wheel bearing?
Auto level air
2015 Rams
Yes, get an alignment check so you know for sure what is going on. If you can document the BJ's are good and the alignment is still off Dodge owes you a new front axle. It is not unheard of they come from the factory misaligned on the C's. You have 2 choices, new axle or offset BJ to correct it.
I suppose the dealer will need to verify the ball joints though, but can I take something from getting the place where I get the alignment checked to the dealer and that be good enough to verify the alignment
The alignment shop should give you a print out of the alignement numbers. Camber I thinl is +\- .3 degrees, if camber is outside that there is a problem.
Well I had the alignment checked and everything was within spec except they said the caster was off a little but that it wouldn't affect tire wear. So I don't know, I guess all I can do is keep the tires rotated and drive it.
I stand corrected regarding the current RAM which is what we are talking about. I was referring (which was incorrect) to the old style axles where you could repack the bearings and set the spindle nut torque. I suspect the new style simply bolts on and is pre-torqued from the factory?
