Wheel gear ratio
CB's with Sideband - What's your favorite?
P.E. for a VA?
I have 4. 10 what size tire rim do I need to get to 3. 72-4 area. Does anyone have any photos of a set up with that effect?
Y2K Limited 4x4 QC the works minus leather & antilock, PE, Grover, SPA, Roadmaster Suspension, Ranchos, (waiting to install)Bill K Trans, 275's... . Maxed credit card
[This message has been edited by madmack (edited 09-22-2000). ]
A quick math run shows about a 295/75/16 or around a 33. 5" tire would put you in the 3. 7x range.
4-sale with less than 19,000 miles. '99, 3/4, QC, SLT, 4x4, ISB, 5sp, 3. 5xlsd, tow pac, HD tcase, tow mirrors, camper pac, White over driftwood, Mist gray interior.
Hi:
Same setup- I put on the 19" ricksons. Around a 33" tire. You will also need to get an abbot box to adjust the speedo. Otherwise your mileage(per the odometer) would go down. For me it put the RPM right under 2,000 at 70 MPH.
P. Campbell 1998. 5 ISB 2500 auto green/driftwood
madmack, Check out Joe D. tire he runs the same tire I do 255/85R16 and they are about 33. 3 inches tall which will put you right where you want.
EAT'M UP
97 2500 Club 4X4 3. 54, Forrest Green/Driftwood, LSD 5 speed, & Psychotty Air System, TST #11 all the way forward, AFC spring kit, Geno's Exhaust Blanket, TST EGT gauge & 0-60 boost gauge in A Pillar, Cat-be-gone, 4" Dynomax Bullet muffler, Crome 4" turn down, AmsOil Through out, Geno's trans filter kit, AmsOil Bypass system, Lund Winter front, Leer Cab Level Shell Driftwood , 255/85R16 Big O ATs, Dyno'd 342 HP *NRA/USPSA member and proud of it*
Go with the D range 255/85R16's ... I run the Dunlops (33. 6" Diameter) and improved my mileage by over 2MPG... best tank right under 19mpg... using cruise and all highway (Florence, SC to Abbeville, Alabama w/1200lbs load). Rairly downshift from OD to 3-4th Clutch... Also filled my wheelwells up in the process WITHOUT having to replace the stock 16x6. 5 rim or adding a lift kit... each tire is rated right at 3000lbs a piece... looks like my set will last a little over 40k... cheaper than Rickson (I paid $130 per tire plus mount/balance/lifetime rotation)... much better than the Goodyears that came with the truck (29K... #ad
) Good Luck!
Rob's 98 Ram2500 SLT RegCab 4X4 12-valve Cummins, Automatic, 4. 10 Axle w/ Lim-Slip, Trailer Tow Pack, 255/85R16 Dunlop Radial Mud Rovers... Silencer Ring disappeared; TC lockup switch, CAT removal, and decent paint next... . 50,000 miles; Wife's 99 Ram1500 SLT QC 4X4 w/360 eng, Automatic, Trailer Tow Pack; STOCKER! 38,000 miles - both daily drivers. If your STROKIN, your CHOKIN... on CUMMINS smoke!!!
[This message has been edited by Yuppie Redneck (edited 09-23-2000). ]
