My 06 mega cab 3500 SRW 6speed wheel hops VERY bad when in mud snow or sand loaded or unloaded. Does any one make a ladder or traction bar that works for this or is there anything out there that doesn't stand out as much as either?
I have been running 315s since it had a thousand miles on it.With the stock size Michelin's my wheel hop was terrible. With 315 BFG's wheel hop was drastically reduced, only a problem on uphill dirt roads!
Who is GDP?I've seen the Superlifts on a friends truck, they are nice. GDP also makes a set, high end pricing but they are really nice. I had BAD wheel hop on my SRW when it was new, don't know if it was just me getting used to a new truck/clutch or what but I also went to 315's early on in mileage. I have only had it a couple times since, but when it happens it truly is a nuisance to deal with. I noticed it is mostly associated with a 1st gear start off, unless I'm towing I start out in 2nd, that seemed to make it go away.
CD
I had an idea of the ideal traction bar a few years ago with a pivot to allow the spring to lengthen without rolling the axle. I was giong to use sway bar links. Well anyhow the GDPs that you linked are exactly what I had in mind for the ideal bar. Now all I need is $600. Thanks to all for the infoHere ya go... Glacier Diesel Power - Categories
