Wheel Hub at 32K
Odering a new truck Questions?
P2201
As Cummins12V98, it appears RAM puts in to much toe in, causing the outside wear. No one commented on his post. Snoking
Truck is at dealership now. So they set toe to 1/4 on the right front? Is this to compensate for road crown?
No that is so that your tires will still wear! RAM says 1/4" so tech set it at that. Listen to what cummins12v98 is saying, and have it set to 1/32-1/16 if you want wear issue resolved. Snoking*
ditto... my '14 does the same thing... going to talk to an alignment shop this afternoon to set to the lower spec as referenced by cummins.
I had mine into the dealer under warranty as well for the issue... they checked everything including alignment and stated its "in specs"... Their spec's are wrong.
No their specs are correct for what they are trying to obtain, straight tracking!
I just wished I had my 15 aligned right away. I was hoping with the new front suspension it would have been better. NOT!
