wcjp,
If you persist and hang a slide-in camper off the back of your truck it could possibly roll over backward when you or your wife open the rear door and step in.
wcjp,
I have a short box 3500 4wd and haul an Arctic Fox 860 camper with a slide out. I run the Toyo 295/70r17 tires for weight rating (3960lbs each). The rear axle is rated for 10800 lbs. Add spacers to the bumpstops (approx 2. 5" box tube) for your overloads so they contact the overloads right away. Your truck will be over its load rating, but so is mine. My camper weighs 4900 lbs wet, I scale at 7400lbs on the rear axle and 12200 overall. Overloaded, hell yeah, but after buying it believing the brochure, what do you do? Use some common sense while driving and loading, buy one that is DESIGNED FOR A SHORT BOX, and go from there. Hope that helps. Cheers, Marc.
Trade it in on a dually. Nothing hauls a slide in hardside like them.BHolm - My suspension saga is fairly involved, but here goes. I originally started with the stock leaves and overloads with the spacers. The truck rode level but still had some bounce. I upgraded to a 5 pack overload but because of the extra size, they hit the bumpstops with no spacers creating a very poor unloaded ride. Next came the 12 leaf Deaver springs (no overloads) to get a good ride. They are soft though and I had to tighten up the shackles so much to keep the truck from sagging that I lost the great ride I had achieved. I added Firestone ride rites to supplement for load and they aren't nearly enough, the truck sags and bouces way too much. My plan in the next week or two is to loosen the shackles again to get the ride back, add a block to get the ride height back to where I want it, add the stock overloads again with new bumpstop spacers, and keep the air bags as a back up. Hopefully, this will give me the soft unloaded ride I've been working towards, and handle the weight of the camper... ... ... . 4th times the charm??
