As a dealer, I sell American Eagle Wheels. Most of what I sell are 8 hole. I personally have several sets on my trucks, and when using the 16x7 on your 2nd gen, the backspacing is almost identical to factory wheels, keeping the tire under your truck. I've broken one Eagle wheel in over 15 years, and bent two. The broken one was overloaded severly, and off road when it broke, pulling a livestock trailer full of horses. And it only cracked at that, and let the tire leak down. They are certainly tougher than the factory aluminum wheels that come from Dodge, and are all manufactured in the USA. If you'd like to look at their full lineup, and check out the specs, I'd suggest their website... . Eagle Alloy Wheels
I presume the wheel you are looking at is the 058 or 186. The weight carrying capacity of these wheels in 16x7, 8x6. 5 pattern is 3040 lbs... . 6080 lbs... . more than the axle capacity of your single wheel truck, matching carrying capacity of most factory sized tires. I have a set on my '96, and love them. That set was on my first '96, and I wrecked it. The front, right wheel was bent where it was shoved back into the front cab mount. It was replaced, but the other three have been running since '98, wreck and all, and I've had no problems. I also pull a lot of trailers with this truck, have a J&I steel skirted bed on it, airbags, and 285/75R16 tires on it. They are excellent wheels.
God bless,
God bless,
Thanks!
What's with the black center cap on the front? It looks a bit different from the one on their website.
Might be a manual hub... .
