When is a 1st Gen no longer a 1st Gen?
2nd Gen. Intercooler on a 1st Gen?
Trippin’ gauges..related to bad tensioner?
I sure hope swapping the steering wheel doesn't change things, the steering wheel I have is out of a minivan. Its still a 1st gen if people say they didn't know dodge put a diesel in them before 94. I better stick with a 1st gen or I might not let girls drive it.
I really dont care. The Title say's its a 93 Dodge 250.
The first chance I get to find all the parts It will have a P-Pump
And hope to have allot of fuel. Laser cut delivery valves,larger Barrel and plungers,and a whole bunch ah more stuff.
Originally posted by CB_Parker
What? It's just a way to look at things. Sometimes I wonder if buying a new truck would be more cost effective and cause fewer headaches than stripping this old thing down and making it like I want it.
And you think the new one will be just the way YOU want it? :D
If I had the money, all of that would be done to my truck. Don't worry about whether or not it's "truly" a first gen or not.
The main reason is because the only true difference between the generations is the fuel pumps.
And the valves... ... And the injection pumps... ... ... . and the gearing manufacturers... . and... ... ... ... :D
Well yeah, but they're all cummins. And that was a typo, by "fuel pump" I mean: "injection pump. "
You know, the more I think of it... the I say the body and the injetion pump makes it a first gen. From there, it's a hybrid if you change it.
First Gen is not having the engine stuffed into the firewall, not having a coil spring front end, a minimum of electronics, and not having heated leather seats to keep your urine from crystalizing... ... . just my thoughts
"... . Laser cut ... "... hey Antrim... . you bad boy... . see what nasty nascar mark has started... . I'm gonna have to give you guys a set of 'laser cut' anterior valves if this keeps up... . geezzzzz..... :D:D:D
Pastor bob... . thou shalt not worship craven injection pumps... .
VE = Victory Early
