Engine/Transmission (1994 - 1998) when is it time?
thats great kevin,mine also leaks out the front cover area,ive even taken it off and replaced the cover gasket and front seal. I believe it leaks betweem the block and aluiminum plate,i think that gasket is about gozo.
bearings
The Cummins will outlast the truck and also the gaskets that keep the oil inside the motor. If you ever get to the point that an overhaul needed, about a million miles, the crank will only need polishing and get ready for the next mil. stormy
