When to replace shocks?
engine/exhaust brake
Just flipped 'em off...err over
I have 108,000 miles on my original shocks on my '91 - rides better than new! Bit softer than when new, and it needed that, but no bounce or sign of fluid leaks, so I'll just keep on truckin'... #ad
http://community. webshots.com/user/davison71 Early '91 250, 727 AT, 307 rear... Banks Stinger exhaust, intercooler... US Gear OD... Tweaked pump, upgraded radiator... MORE than a match for every new PS Ford encountered so far...
"Dura" WHAT? NOW I know where all those recycled beer cans go...
I've got 51K miles on my truck. Other than feel, is there any recommended mileage interval on when to replace shocks?
1999 Dodge Ram 3500 Quad Cab 2wd; 5 spd; 4:10 LSD rear; Mag-Hytec differential cover; US Gear EGT and Boost gauges. Stewart Warner Fuel Pressure Gauge with dual senders, Westach Oil Temp Gauge for differential. Amsoil foam air filter and synthetics in the motor and differential. Cummins Power, don't leave home without it
John, the shocks they are putting on the newer trucks are absolute garbage at best. I have had three sets of OEM shocks in 60K, alll replaced under warranty. If you want to know how bad yours are put on a new set. I bought a set of Rancho 9000's to put on mine and am very happy with them. I could have had another set of OEM shocks free, but I am tired of bad ride after a few thousand miles. My truck is run on the highway exclusively by the way, no offroading or other mischief to tear up shocks.
99 2500 QC 4X4 AUTO SB 24V LARAMIE SLT 3. 5 LSD 285-75-16'S SPA Boost/EGT Everything but leather NRA Member Great Lakes TDR Member
John,
I have 112,000 on my shocks. Have never changed them. Have towed a lot of weight too. My shocks are OEM.
When I start getting a bouncy ride I'll switch to the Rancho 9000, lots of folks seem to really like them. Most of our driving is on the interstate.
I also will add some type of air pillow to help support the 14k 5er, and horse trailer.
Bill Cook
'98, 3500, 112,000 miles, 12 valve, 4x4, QCab, SLT, auto, 3. 54, tow pkg, Pro-Loc TC, TST #8 plate (230/605), BD exhaust brake-presure lock-torque lock, heavy duty valve springs, Mag-Hitech trannie and diff. covers, transmission and pyro gauges pillar mounted, K&N filter, 14k 36' fifth wheel, 12k Sooner 4horse gooseneck, 13K (when loaded), 24ft gooseneck flat bed.
100k mi on oems
IMHO they should be replaced at the dealership when delivered with adj Ranchos, best of both worlds for m/t and partial to full loads. Better ride and control on and off road.
2K, 2500, Quad, SB, 4x4, 3:54LSD, A/T w/ DTT VB, TC, TC SAVER and AUX COOLER , REESE 15k 5th slider, EASLEY BULL BAR, MAAP NERFS, BFG-TA's, 9000's,TORQUS MAXIMUS 505 lbft ECM, stealth DD2's, Bully Dog Boost & elbow, ISSPRO pyro, boost & transmission, Turbo Lifesaver, JARDINE 4", PAC BRAKE, MAG HYTECH TP& DC, AFE filter, GEAR VENDORS OD, TAYLOR WING onboard.
MxM's on order
pullees:
#1 y2k ARTIC FOX 5th
#2 22' car hauler w/ 76 Pinto 392cid or 68 Cyclone GT Cobra Jet FB
NRA-LIFE, VFW-LIFE, SoCSA-LIFE, SASS
[This message has been edited by JNutter (edited 05-02-2001). ]
The Ranchos were ordered this morning. Got em at hotrod-offroad.com. Good price, too.
$244. 96 incl shipping #ad
Thanks for the input. I really don't know whether I need the shocks right now. I was going to replace them when I got new tires(probably sometime next spring) but I decided to beat the rush and spread out the expense.
If you get the cab control with the 9000s be sure to do two things. Lighly grease (lithium-based ONLY) the o-rings before you install them on that air lines. Get some good air valves for the air bleed lines. I had leak problems with the original valves. I did the above to my setup and the leaks stopped.
2001, 3500, 2X4, QC, SLT, Auto, 3. 54 gears, camper and tow packages. Lance model 1130 camper. Rancho 9000 5 Speed shocks. BD Brake, autoloc, pressureloc. Hadley air horns. Cummins mud flaps. OEM bugshield w/eyebrows and dash cover. Member San Jose Ram Runners.
