How does the Attitude connect to the truck? Does it connect to the J1939/CAN connector (connector by the lift pump), or does it connect to the under-dash OBDII connector?
The VP44 sends data back to the ECU over the CAN bus. One of the things it sends is the fuel temperature, that is read from a sensor that is on the FPCM/PSG circuit board.
So, I am sure that anything that connects to the CAN bus can read this data, I'm not sure if it is available from the SCI/OBDII connector.
