My 89 has a big hash mark on the right and a big one on the left. Between them are seven little hash marks - no numbers. My needle rides on the third small hash mark most of the time, but drops down to the second at idle. I've got no clue how much oil pressure that is, but all the Cummins manual says is that if the red light is not on, everything is OK! How do you boost oil pressure on Cummins? Is there a relief spring you can shim like on a small block Chevy?
http://coffeewithJesus. homestead.com/web1.html 89 1-ton, Amsoil System 3000 5-30,K&N air filter, cleaned-up exhaust, Dynomax straight-thru, rebuilt pump, 12cm wastegated turbo, thermostaticly controlled twin 14" electric fans, intercooler, modified 518 OD transmission, Gear vendors OD controler, R-134, louvered fenders, 93 aftermarket smoothe grille; 78 35'Avion, 93 Lance 900 slide in with generator and power jacks. Jesus saves!
