Where is my boost?
Exhaust
Bombed
Ok guys, I keep reading these boost numbers and am not even close. I have a 93 5 spd. As far as I can determine it was stock when I got it (69K miles)
The pump does not ever appear to have been tampered with. I put the boost and EGT on prior to turning it up. It would run mostly 0psi @70mph level ground, but would go to 14 WOT.
Now at 133K. I went to 16cm hot side housing, smoke screw in +2 turns, full power ~+ 1 3/4 and star wheel 2 1/2 from the bottom, diaphragm at 3pm. New airfilter, fuel filter and set valves.
Oddly enough the star wheel was 5/8 turn off of bottom when I started. The diaphragm was already at 3pm. The smoke screw is pretty much flush with the top of nut now. The pin is making a mark (line) on the diaphragm shaft so I believe it is free. If someone tweaked it they did not leave a mark. The paint on the screws was intact.
So now I can get 2-3psi at 70 mph on flat ground and will go to 24psi WOT. EGT runs ~650 deg at 70 on flat ground. Will climb to 900 deg on a hill unloaded. It also will blow a thick black cloud off the line if you get on it until the turbo spools up in lower gears.
It runs much stronger than it did originally.
I see no evidence of leaks to the intercooler. (how would you check anyway?) What adjustment actually builds the booost other than turning the fuel up? Any ideas?
24 pounds with your mods sounds right on the money. If you want more you made need to get a 14 or 12cm turbo housing and a set of injectors. But as far as I can tell... your reading are right.
cody
91. 5 4x4, 5 speed, 3. 54 gears, lucas injectors, 12cm turbo housing, K&N air filter, "tweaked" pump, isspro boost and pyro gagues w/A pillar mount, straight piped 3' exhaust
24 is ok ,my pw inj added about 3-5 more
1993 w350 ex cab, banks,nv 4500 in
open exaust, pw Injectors are in. Big rig flaps,tach in,. Its loud and goes ok, for a 93,Ham radio Call KK6dm
has ability to communicate any where in the world. Headliner shelf
5 antenna's
24 does sound right. When just cruising down the road you gauge will probably be 0 or very little. Only when you are giving it the gas or putting a LOAD on the motor will the boost come up. Mine is 25 WOT on a cool night. Injectors is my next performance purchase, then you can turn back the pump a little a save it and get even MORE boost.
Scott
92 Ram, Bright White, Club Cab, LE package, 4x4, 130K, 3. 54 gears, Auto, Extra transmission Cooler, 285x75x16 Cooper Discovery A/T, 16X10 American Racing rims, RS9000, Tekonsha, Running boards, Lund Sunvisor & bug shield, Marker lights, Tonneau cover, Full cap, DynoMax, 5" Chrome tip, 16 cm Turbo, Isspro Boost, 23 lbs Boost empty, Oil Pressure Gauge, Pump Adj, Sprayed in Bed-liner, Rubber mat
'SHAKES, RATTLES & GOES'
