Engine/Transmission (1994 - 1998) Where is the idle.
Engine/Transmission (1994 - 1998) Update on Hard to Start Issue
Engine/Transmission (1998.5 - 2002) best year of 24v truck?
Originally posted by SEmerson
Nevermind I found it in a old tdr mag.
Try getting to it!:rolleyes:
Gonna have to get some of those replacement plastic pins for the inner fender before I can do mine. Aww heck that means I'll have to do it again when I put in my GSK!:{
I was told they pop out, but I tried one and it broke!:mad:
Its not too bad once you figure out where it is. It takes 10mm wrench to loosen the jam nut, then grab the throttle rod and open the throttle and the adjuster screw can be turned by the other hand. Use a mirror to see what you are doing and then its pretty easy to do once you know where everything is.
If your truck has four wheel abs system, You just can't reach it laying on the fender. If I stand in front of the headlight, its a piece of cake with a sledge hammer holding the throttle down .
Michael
