Originally posted by Bob Wagner
I've run DD3's and Mach 3's are a major increase in HPand Torque
I would not use the Mach 3's in a towing situation.
Put for playthese injectors rock.
Mach 2. 4's and lower are recommended for towing
EDM Mach 3's have been producing 140HP gain and you also have to factor in the torque increase too.
We can only make recommendation, The buyer makes the final decision.
BTW, The 100. 00 off sale with be running for 2 more weeks![]()
Originally posted by Idaho CTD
Ken,
If you want 500hp you might look for a little bigger than Mach 3's. The highest Don had dynoed (no correction factor) with a B1 is ~530hp and that was with Mach 5's. Usually DD3's run around 440-450hp with 0 correction factor so you'd need closer to a 150hp injector. A 3. 5 would probably get you there but it will make towing very heavy difficult.
Originally posted by kbond
This is what I was looking for. I don't see the 3. 5 on Rip's page? are they not part of the "Mach" series or do you have to call and ask? I tow 5500 pounds once a week in the summer. Also I don't mind turning the boxes off or downtuning them to control smoke and egt. I have talked to many people regaurding DD3's not atomizing very good so I am really anxious to see how much better edms really are.
