Engine/Transmission (1998.5 - 2002) Where to get a new gasket
Engine/Transmission (1994 - 1998) Timing Troubles
Engine/Transmission (1994 - 1998) Transfer Case What Happend???
When I first got my truck & installed gauges I did everything safe (paranoid :eek: ) lol and seperated the turbo from the manifold to tap the manifold. Well I took off the Turbo Oil Drain Line and when I was finished put everything back together... Every now and then I check under the hood just to make sure everything looks good & There is some oil seepage running down that tube. Both bolts are tight so I'm figuring I disturbed the gasket & now I would like to put a new one on...
Does anyone know the part number & where I can obtain one?
this pn may be outdated but it should get you there
cummins 3285747
local cummins shop or I know city diesel would send you one
