visors , leaking cab lights
For 1st gen trucks the front roof lines are the same for ALL 1972 to 93 100 to 350 trucks and ramchargers... the 100 to 350 visor will also fit all D and W series 600 threw 800 conventional trucks built 1973 threw 1977...
Visors like the one Lund makes are a real bad idea to use. They warp the hell out of the roof skin . They also LEAK water into the roof area and cause the roof to rust out ! Salt water in the winter blowing over the roof does wonders
when it leaks in the bolt holes. And lets not forget those leaking cab clearance lights on the 350's
For those that do not wish to heed my warnings. I have about 12 of the Lund visors that I have removed from trucks... I would be more than glad to get rid of them... Those interested please send me an EMAIL
If I felt that I had to have a visor . I would spot weld studs to the roof with out drilling any holes in it. . Then use stainless acorn nuts and washers to hold
the visor on .
As for cab clearance lights , remove the head liner . Drill access holes under
each of the lights. Get some general auto body calk (NOT SILICONE) . Then
calk over each screw hole and the large center hole... TIP, the center hole is large. Use round knock out slugs from home electrical boxes to help fill the hole with min. calk. . You might also want to replace all the bulbs before you calk them in... 3M sells spray can of "interior panel rust preventer" Spray it
all threw the interior roof panel areas. Especially towards the windshield area.
If you live in the "rust belt" where they salt the roads . What I mentioned
above is very critical !
BSchwarzli said:
I was speaking with Lund, and they daid that you cannot use the reg cab visor with a club cab. Any one have any thought? Is it the roofline shape? Drip rail? I thought that both trucks were the same? Lund said that they would not have two different part numbers if they were the same. Any thoughts?
