Where to locate BackUp Lite Relay?
Diesel Dynamics Phone #
Caring for Alcoa's
Planning on running a wire from Battery to
rear of truck to power aftermarket B/U lites.
Will use relay,per ArticCat,and Evan Beck,to switch power.
Doesn't seem to me that it will matter where
I put the relay along this line.
Or does it?
Thnx
Fuzz
Fuzz, I'd say mount the relay wherever you want, it's probably a good idea to fuse the line as well. I like the KC light type relays they sell at the parts stores for around $5, if mounting under the hood I wouldn't worry about sealing it off. If you mount it in the back of the truck, you could probably tap into the trailer harness for power.
I'm a few miles down the road from you in the Tech Center, send me an email if you want any help.
Pete
'97 2500 CC 4X4 5spd Sport
'83 K5 Blazer 350 TBI (ex 6. 2), 39. 5 TSLs, 3" lift, Dana 60/GM 14 blt, Detroits
You can get a project box from radio shack for a few bucks. Put your relay in it and seal from weather, put close to lights and some place it wont get torn off. Just my 2cents worth.
Eric Pitts 2001 Properly Valved 2500 Qcab 4X4 auto Transgo shifts it 4. 10 LSD Weston Nerf Bars Smith built brush guard Command Remote Starter Scotty Air DD stage 1’s, PS boost module , elbow 32psi boost 247hp,657tq Neophyte B. O. M. B. er Hella drive/fog lights,Aircraft landing lights
The Pitts Home Page
Member GLTDR
