Where to tap power for gauges on a 2006
What is the "FCA"
Thanks Dan and Will. I will give it another look this morning. I think I remember seeing what might be the power pedal connector. I will also check out how that cigar lighter comes out. Sounds much easier than what I was trying! Thanks again. This is what makes the TDR so great!
I just wanted to report back that all went fine today and I tapped into the grey wire going to the unused conncector behind the dash and below the headlight switch. This is my second Westach Combo gauge, and I am sure glad I got the 0-50 psi for this truck. I was surprised to see my pretty much stock truck hitting 30 psi boost and 1100-1200 degrees just hot rodding around without pulling anything! Anyone adding fuel enhancements to these new trucks better have some gauges.
Those are pretty common numbers with the third gens. I have actually hit 1300 degrees, pre-turbo, climbing some steep hills, and 28-29lbs boost. Truck is totally stock...
Mine will hit 30 psi boost and 1150* pre turbo all empty driving. Hopefully next week will be hooking to the trailer and see what the numbers are towing.
Will
