Hey yall,
Anyone had to replace the Alternator on the 10-12 4th gen truck? Yesterday i started to notice this low whirring sound when i started the truck. Only heard from inside the Cab and under light throttle in neutral. Seems to go away as the day warms up or the truck is warm.
Checked power steering pump for leaks and fluid. it was all good and it doesnt make the typical sounds like a pump would when low or going out and needing replaced.
Tested batteries and Alternator at Autozone and O'reillys and they all tested good both times. I am wondering if maybe it is the bearing for the alt pulley? Already replaced the Tensior and idler earlier this year with a Geno's Garage replacement and the gates belt as well. Alt has 188k miles on it and is factory.
Which alternator did yall end up going with when replaced and from where? I see the Mean green unit on XDP for 380$ and says that it has up to 340% better charging. NO exp with this brand so not sure on it.
