wlowe and Allnew2Me,
You are both correct... here is the response I got from Odyssey:
Thank you for your inquiry. Yes, they are both produced using the same AGM, non-Spillable (Dry Cell), pure lead technology. The 1700T was the original BCI Group 65 battery we produced however issues with it not being a direct “drop-in” battery for all "group 65" applications caused Enersys to produce a true Group 65 battery. If you compare the two models, the dimensions are not the same and a metal jacket would be required for the PC1700 if it is going to be exposed to temperatures above 113°F. Either model would work equally well in your application.
Sears... here I come!
