which exhaust is the way to go
Where do you order your accessary's from?
EGT ? Stock Engine
i have seen several types mentioned here but wanted input on which one i should go with as far as price and quality
Y2K 2500 4x4 ext. cab 8'bed nerf bars,Linex,xtang cover bug shield, husky liners,every option but leather and cab lights remote starter auto 3. 54 gears
98 grand caravan (for wife) 93 harley davidson fatboy
open tubing! some guys have done DIY for $50 or less. (mine was a custom job that may be a little overpriced, but i dig it, and the drivers on my right-hand side don't. that's what's important)
I used a BD cat back 4 inch muffler & tailpipe. The install was easy and the price was ok. Mine is a 96 and I tried a straight pipe to eliminate the cat & muffler and all i got was more noise & stinky exhaust. I think that some guys think that they get more power because of the increased noise. Just like KN filter, probably breathes better but can't tell any power diff. sometime you have to think you got more power because of all the money spent.
Jardines is a bolt up with all hangers and good muffler, NO I repeat NO welding. Aluminized pipe and good fit and finish. WWCD2 arranged a gp for TDR members It is less than $450 adn I believe no shipping.
2K, 2500, Quad, SB, 4x4, 3:54LSD, A/T, reese 15k 5th slider, EASLEY BULL BAR, WESTIN NERFS, TA's, 9000's, stealth DD2's, DD Boost & elbow, ISSPRO pyro & boost, Turbo Lifesaver, JARDINE 4", DTT VB,TC,TC SAVER and AUX COOLER, PAC BRAKE, MAG HYTECH TP& DC, AFE filter onboard. Taylor Wing and Gear Vendors on order
pullee #1 26' Arctic Fox 5th
#2 22' car hauler w/ 76 Pinto 392cid or 68 Cyclone GT Cobra Jet FB
NRA-LIFE, VFW-LIFE, SoCSA-LIFE, SASS
I think that your going to get alot of replies to this topic, might be a good idea to see if you can meet up with a few members in your area and check out their rigs. I went with the BD 4" turbo to tail and am very happy. Personally, I wouldn't want it any louder. The BD has a good "drone" at heavy acceleration and is fairly quiet under light throttle.
Scott W.
White 2001. 5 3500 ETH/DEE 4X4 Quad cab SLT,tow package and camper prep,Husky liners front and rear,DiPricol pyro,boost and oil temp gauges,Edge EZ,Psychotty air,Bully Dog stage III injectors,ATS 3 piece manifold,HX40 turbo,4" BD exhaust,4" BD E-brake,McLeod clutch,Mallory 4150 lift pump,Mag-Hytec rear,Mopar tonneau,Lund bug shield,PM tractor utility back up lights,Penda bed mat and blow by bottle is bye bye !!! I love the smell of diesel in the morning, it reminds me of... . VICTORY !!!
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089608" TARGET=_blank><font color=red>My Truck</font></A>
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089604" TARGET=_blank><font color=red>THE SAINTS</font></A>
I agree with JNutter, I have the Jardine, High quality, AWESOME sound and bolt right on! You can't go wrong with the 4" Jardine! Don't forget the 5" Chrome Monster Tip from Geno's.
I remove the stock system and installed the Jardine in 2 hrs 15 min. all by myself.
<font color=blue>"WHITE OBSESSION" 99 Quad Cab, White, SLT, 4x4, 5-sp, 3:54's, Raven cap (cab high), Rhino liner, Stainless Nerf Bars, Stainless Rocker Panels, Tow package, Valentine One, Uniden PC78LTW CB, Hadley Bully Air Horns, HOT Power Edge, Bully Dog Stage III injectors, Psychotty Air Induction, Braided SS Fuel Lines, 4" Jardine Exhaust (Love the deep throaty sound), Bar II Brush Guard with KC Daylighters and Fog lights, Ultra-lite guages with blue bulbs. </font>
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1086000&a=9265455" TARGET=_blank><font color=red>New Pictures of my "White Obsession" and Dyno Run</A></font>
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1086000&a=9815423" TARGET=_blank><font color=green>BD Dyno Days 10/28/00</A></font>
<font color=purple>
NRA Life Member! (Need to protect our rights and FREEDOM!!)<font size=-2>
[This message has been edited by BIG BOB (edited 02-28-2001). ]
JNutter,
What was the final fix for the drone you had with the Jardine exhaust system? I got one of their systems on my '97, love the sound untill you hit the drone rpm range of 1900-2250. Found the 'drone' to be rather annoying on cross country trips. I have put clamps on the exhaust pipe at about 1 ft inervals which helped but did not eliminate it entirely. TIA
1997 2500 Ext Cab 4X4,5 spd,3. 54's,Pac brake,Rancho 9000's,Centerforce clutch,K&N airfilter, Isspro gauges,TST #11 plate (280hp/680tq),AFC medium spring, Jardine 4" exhaust, 370 Diamond B marine injectors and 16cm turbine housing.
R. ebel: Jardine now has a larger muffler that seems to work just fine. I have made some conversions from the old to the new muffler with good results.
BD makes a good quality kit. Banks offers a high-end stainless kit that is also good, but expensive. But you'll only do it once. Either way the aluminized kit is good for diesels as the aftermarket kits tend not to corrode away as easily as the stockers do. Bigsaint has got a great looking and sounding system on his truck. I've seen and heard it. Really the decision is going to finally be up to you. How much you spend, how easy the kit is to install, and overall fit and finish are things you're going to have to figure out as factors into what you end up buying.
Chris Timochko
AUTO WURKS DIESEL R&D TEAM
1997 5sp 4X4, Rhino Linings, Espar Heater, A. W. D. HX40 turbo, ATS 3pc Manifold, BD 4" Brake, Marine Compression, A. W. D. Custom Tuned Injection Pump, A. W. D. Intercooler, A. W. D. 370B Injection Nozzles, Delivery Valves, Governor & AFC Spring Kit, Psychotty Air, A. W. D. Water Injection, NOS Diesel Kit, A. W. D. 6" Chrome Exhaust System, BD No Smoke Valet Switch, McLeod Dual Disc Clutch, Mag-Hytec Rear Cover, Cummins Chrome Kit, Optima Red Tops, Hadley Bully Horns, Hurst Line Loc, Goodyear Wrangler AT/S 305/70/16s. 15. 50@97mph on Goodyear All-Terrain tires.
Project U96 - 1996 3500 2WD racer. A. W. D. Marine Ultra Low Compression, A. W. D. Teflon-coated Pistons, A. W. D. High Lift Camshaft, Ported and Honed Cylinder Head, Intake and Exhaust manifold; A. W. D. HX40 Turbocharger, ATS 3pc Exhaust Manifold, A. W. D. Water Injection, A. W. D. Custom Fabricated Fuel System, Race Spec A. W. D. /BD P7100 Injection Pump, A. W. D. Custom High Flow Fuel Injection Nozzles, BD Auto transmission and Custom TC, Weld Draglites, Goodyear Eagle Drag Slicks, 5" Single Stack Through The Bed, Mag-Hytec on Rear and Transmission. 11. 54@115mph
BPINE: The system that I got has the 30" Magnaflow muffler, is this the same as the newer muffler you are descibing?
I have the Diesel Dynamics 4" system, I love it. Sounds good, no drone to speak of. I have to be honnest though, the only reason I chose it was that I had a way to get it to Alaska for free (thanks Dad) and that saved me 150 bucks.
The shop that installed it said it was a piece of cake, took more time to get the old system off than it did to install new one.
John D. Rathert Jr.
01 2500 Forrest Green Sport SLT+ QC LWB 4x4 Auto 3. 54 rear end with all options avail. DC Nerf Bars, DC Grill Gard, DC mud flaps, Line-X bed liner, Leer 160XL Topper, Power Edge, EZ Edge, SPA Boost/EGT Gauge on pillar mount, DDT's tc/vb combo, 275 RV injectors, DD 4" Exhaust and a KN RE0880 where the air box use to be. New turbo (HX40), SS fuel lines and bigger injectors in planning stages... . See My Truck, Dads truck: 98. 5 3500 SLT QC LWB 4x4, Brother Truck: 92 W250 SLT CC LWB 4x4 (Dads old truck) Winter fun - 2000 Skidoo Summit 700
EXTREME1,
installing this housing on my 1992 truck made no change in the installation of the exhaust.
1992 W-350 Club Cab Dually 3. 5" straight pipe(thanks jardine!)
W-350 8' contractors dump with 3. 5"BD exhaust, 16cm^2 housing, DI pyro&boost
Russell
Jardine: Best Fit, Quality, Price. A four-letter word less installation and to top it off, a straight thru muffler, I'll use it some day. . . #ad
A related question: if you install a 16 cm turbo housing, does it affect the install? I know the stock system must be moved ahead.
I see that some of the other 4" systems Droan at 19-2100 rpm.
The JRE 4" system Does Not, I repeat Does Not Droan at all.
Our new systems are now available with no welding and comes with a really neat looking Chrome 4" oval tip.
Ted Jannetty, Owner President, Jannetty Racing Enterprises, Inc.
97 3500 4x4 club cab 5spd. RED, JRE custom power kit, JRE 4" exhaust
JRE 1/2 inch fuel system, Bosch 300 hp injectors, Prime loc,
Cummins chrome kit, US Gear 20% over drive, 3. 54 posi, Autometer
Ultralite 50lb. boost, and Pyrometer, BD exhaust brake.
Horton fan clutch
99 Ski-Doo 800 Formula III Pipes, reeds, studs and clutching 172 hp
99 Honda Forman 450 ES jet kit, pipe, lift kit, 27" Mud Runners
2001 Ski-Doo MXZ 800 X stock for now 140 hp
2000 TransAm Ram Air WS6 Flowmaster, K&N, Granatelli Mass air meter, LS1 Lid 370 hp
1973 Camaro Rally Sport Street Strip 850+ HP
I keep reading about "droning. " What do you guys mean by "droning?"
I just installed a DD 4" w/ Walker muffler. The system went in okay, but mkes a rattle at moderate acceleration. Is this "droning?"
When I mentioned the "drone", I meant the pitch of the exhaust sound, not the sound of a rattle. I have NO RATTLE at any rpm's. Just wanted to clear that up. The BD kicks a$$ IMHO.
Scott W.
R. ebel yes it is. I order one for my truck yesterday some how my truck ended up with a combo of 3 different systems. Now it will be all Jardine. Anyone interested in a Banks Muffler and tail pipe?
i have the JRE 4 " system with a dynomax race magnum muffler . though it had to have the hangers welded on , which IMO made sure it was placed away from things it shouldn't have been hitting , i did elect to have it installed at JRE and was very happy with the outcome and it does not drone .
as far as it not adding HP , my times slips from a same day comparision at the drag strip showed a 2MPH increase in trap speed . MPH IS HP , plain and simple .
