AH64ID
Why not use an Air Dog that have 165GPH and 2 micron filtration and removes the air out of the system from two air removal circuits vs just one like other brands do?? By passes the stock filter housing etc??
Mark
There is no AD system with greater than 5um filtration, and 3um is the best available. They both have their faults with filtration, FASS seems to be addressing the issue slower than AD, but still addressing it.
8-12 Psi anything over 15 is a little to Much,20+ will accelerate wear on the pump gears. I suppose if I wanted to save My lift Pump I would run higher pressure so the COV bleeds off more back to the tank,but eventually the COV will wear out then its going to be $$$ in repairs. .
I agree, Bosch specs are -5 to +15 psi, I would set it 15 at idle and let it drop from there.
