Which fass???
hard starting,,
Backseat Bypass
Going to change out the in tank lift pump. Wanna put in a Fass pump, but not sure which one to get. I am looking at the Fass95, but have also looked at the water sperator one also. Any help would be great!!!... TIA, Scott
Better idle along with better fuel delivery would be great, as I can hear the difference in the idle, although it does not show on the tach. Does the 150 give me room to upgrade injectors without running into supply problems?. . Scott
LowFly, I was trying to PM you, but I couldn't. How do you know if your supply pump isn't doing the job?
Hook up a fuel pressure gauge and see where you are at. At WOT if your not getting enough fuel from the pump you will feel a hesitation. I'm guessing that you are not getting enough because i have less fuel mods than you and i cannot go above level 4 on my Edge without starving the CP3. Pump is coming shortly for me.
