lift pump good for something....
filling that canister with clean fuel. . I clean the canister and screw it on with my fingers, so its loose. Put a tarp or catch pan under the front axle and bump the starter... let the lift pump do the only thing it can do right... Once I have fuel spilling out the top I open the drain a little, and bump the starter two or three times. . Then tighten once most of the air is drained out. Its a bit messy, but doesn't lead to air in the fuel system. and I don't have to bother with getting filtered diesel wormed in through the engine bay in the canister
First time I changed it I just screwed it on tight (and empty with the water drain open after it was mostly full). . took a lot of cranking before it finally started. .
Now its messy but starts right off w/ no stall. Lots of ways to do it. . At least I know the lift pump is pumping some fuel.
