WHICH FUEL PUMP AFTERMARKET IS BEST ANY STORIES
update: Engine misses upon acceleration
turbo silencer
Well i am on my 2nd carter and curious what others are using u can see my upgrades by my sig and was wondering about these holleys and the mallorys what pepole like best and why thanks for all the replys in advance
99 24v auto 3500 4x4 reg cab 3. 55 axle,ez edge,275 injectors,k&n,rhino lining, tinted glass, tonnoue cover heavy duty trailer tow set up goose neck hitch draw tite brake setup,cb,cd player,catz back up lights,amsoil frnt to back,jre exhaust4 wire blue box,bd exhaust brake,transgo shift kit, a pro torqe extreme convertor, and a magtec trans cover and trans guage,JRE fuel line kit,upgraded fuel pump,braided fuel lines from lift to injector pump,reflashed ecm,fuel pressure guage,3 guage pillar,boost&pyro
Barry Grant 220. About $10 more than the mallory. I went with it after I heard some people having trouble with Mallory. Mine works great, can hardly hear it, got it set at 13 psi, have yet to see it dip below 11psi. Comes with the regulator (more like a bypass valve since it doesnt restrict flow. Instead it transfers excess fuel back to the tank via a return line. I guess the restriction on the pumps is pretty hard on them. ) that must be used, because at 220 gallons per hour, the pressure is way too high to run unregulated.
Always ready to help!
2000 2500 Red Sport quad cab, 4x4, K&N, DDI's, straight piped, boost, pyro and fuel pressure gages, Hot Power Edge, EZ box, race transmission, Barry Grant fuel system, mean looking set of 33. 5" tires, Snap On diamond tool box, Marine Corps window sticker, Semper Fi!
1972 340 Cuda'. Original tripple Black, 340 car w/air. Good clean car, super stock springs, Weld Prostars, shaker hood, strong 340 with a 727/4000 stahl, 4. 56... . Bombs away!
NRA Life Member
My Diesel Page
I installed a mallory 4140M today. I did not hook up the regulator today, at idle it puts out 11-12psi, and at WOT it was down around 9-10psi. Going to run it a while with this hookup and see how it does and see if I need to put the regulator in.
Morph.
'99 2500 4x4 QC Std transmission, Purple (usually Mud Red), 10 Disc Changer, 285x75Rx16 BFG Mudders, Amr. Racing Baja Wheels, Gooseneck hitch, 275lb King Klaw front bumper, Towing/Camper packages. DDIII's, Exhaust, TTPM, Boost Module. Fuel Pressure, EGT adn Boost Guages. Mallory Fuel Pump. (fastest farm truck around). And can't forget the hydraulic PigSticker.
1965 Chevy 1/2 ton Pickup, 350-350hp/2spd powerglide, PS, PB, Disc Brakes on the front, Tilt, Fuel Cell, 3. 73 posi.
26ft Gooseneck Flatbed Trailer, 2 horse bumper pull, Round bale Trailer.
1960 Farmal 340 Diesel Tractor.
[This message has been edited by Morphious (edited 03-10-2001). ]
Well, I just put in the Holley hly12-815, in the OEM location, & upgraded lines last night and just got back from a 30 minute test drive and I'm not impressed at all--last night it idled at 10-11 psi(pressure sender at post filter) and I thought great as it was steady(factory would jump from 9-14 psi)--this morning went for about a 10-15 minute test drive and got a low of 7 @ WOT, but it went right back up to 10-11 psi when I backed off--ok not bad I thought, definitely a lot better than the low of 2 psi w/ the factory pump. With the factory pump the psi would jump from 7-11 w/ the red light flashing on my guage saying it had dipped to below 5psi under normal conditions. So, tonight everything is just like this morning's test until I turn off the overdrive and under WOT 4psi--now with the OD turned on it jumps between 5-9psi and the red light flashes more than the red lights in the red light district in Amsterdam--I'm PI$$ED--don't know if I got a factory POS or these pumps are just POS's to begin with!!! Anyone have some insight?--chris
chris sutton
1999 2500 24v qcab longbed 4x4 red sport w/ all the options 'cept plow pkg, 4:10 detroit locker in rear & front ARB,
5" skyjacker lift w/ 35" BFG MT's on 16. 5x9. 75 Weld rims, black smittybilt step bars, black 3 pc. bug persuader,
black lumber rack, camel leather int. w/ mb quartz spkrs and JL Audio twin 10"sub stealth box under rear seat , PE EZ, DTT vb & tc, mag hy-tec transmission pan,
red magview diff covers front & back, SPA pyro/boost&fuel pres/oil temp on "A" pillar,K&N,Holley lift pump & upgraded fuel lines & coming soon: big injectors,HX 40 massaged,red L&L ladder bars,turbo temp monitor,
4" Jardine exhaust, ATS manifold, and PE box tweaked--the above is a big fat lie I really own a totally stock RAM
[This message has been edited by csutton7 (edited 03-11-2001). ]
Scott give me until next weekend and I can give you a report on the one I am installing. It's a Summit pump, 140gph @ 18psi, $99. 99. I have never seen a Holley 815, nor am I an expert on fuel pumps, but just holding the Summit in your hand it feels like a solid, heavy piece that is very well constructed. It is twice the size of the OEM Carter.
