Which Gauges
HO Turn Up
04 -20* no plug in?
Which gauges are the most important to install? I was considering the steering column pod and was going to install the EGT & Boost gauges and I am not for sure how important the transmission temp is. I do pull a TT in the summer months so I am not for sure if the transmission gauge would be better than the boost.
I dont want to loose the grab handle so the A-Pillar is out of the question.
Any ideas would be appreciated.
JIM
Well, I have the steering colum mount and I fine it nice, I can still see the spedo, tach , ect. If you like your grab handle, and don't want to loose it to a a-piler mount, they make a surface mount that would go on top of the dash. And you could also use the mounting cups, which could go anywhere.
I am alittle confused, so I think all gages are important. If I had to choose only two gages, then I would go with the boost and EGT. While the boost may not be so important to others, I find it very entertaining.
If you want 3 guages you could get the steering pod, and then the single pillar mount that dosen't require the handle to be removed.
