This is a customer's '93 auto. Misses cold and smokes blue gray for maybe 30 seconds, then clears up and runs fine. No hesitation on cold start at all. I sent injectors and pump in for repairs as the pump was leaking. Still does the same thing. The thick washers were in place when I removed the injectors, so I reinstalled the same. Are these the correct ones for this app, and can the wrong ones cause this problem? On my '96 215 the thin ones (don't reacall the thickness of them) are the correct ones. Not sure about this application, as has been worked on before.
Thanks in advance, Smitty
