Which Injectors??
FASS fuel pumps
Flux 2 + 2 great shops= good times
I am upgrading my ride and am wondering which injectors i should install?
Current mods are in sig, plus: Hot program, AfeII, Intake horn, heater grid delete, fluid damper and DD clutch.
Mods already on order: Twins, AirDog, Traction bars, e-brake.
I tow often. With the twins, I shouldn't be getting so hot :eek:.
The shop suggested that 50hp injectors would increase power without sacrificing mileage too much, but will 90hp ones hurt it that much more?? Will it start getting hot again??
I'm not running nearly as much power as you. I also didn't see how much you tow. With my 06' Mega, 90hp DDP injectors and Smarty on 3, towing at 19. 3k GCVW EGT's are no problem. I also do the speed limit while towing uphill.
I just had to make the same decision and i went with flux 2s . I figureyou can always back down on the programing but its a biggie if you want more.
Smoke can be a problem once you go to stage two injectors. I run F1's 50 hp and I can really push smoke if the trans wants to hang in overdrive. Buddy of mine is running twins and F2's. He now is rethinking cause he doesn't like all the smoke. He has a 6-speed 03.
More smoke from here. I've been running Jammer Stage II nozzles with a Smarty for the last couple of months. Even on the stock software, my g/f noted the black smoke as soon as I pulled away from the first stop.
wcjp, I tow pretty heavy, in the 24K range, but that is about 3 times a year. The rest of the time, is daily driver.
MA2LA, Thats what i'm thinking!
