I put a double deep on mine, and the pan is still higher than the cross member. So unless you really play hard in the boulders, I wouldn't worry about clearance. The cost difference isn't too much, and they are tough as nails. Both come with a gasket and sensor plug for a temp gauge. I'm sure either is fine, but the double lowers the temp a bit more. Hope this helps.
TP
