Catcracker,
I recently read an interesting article on Engine oil filtration, you might be interested in, so here it is.
According to the (SAE) Society Of Automotive Engineers paper 881825, AC Spark Plug and Detroit Diesel Corp. performed a joint study of the relationship between the level of engine oil filtration and Engine wear rates, and found finer filtration reduced the rate of Engine wear.
Diesel and Gasoline Engine wear rates were established by building a Diesel and Gasoline Engine with fully inspected wear components and inspecting them after the test. In both Engines, the upper and lower main bearings, oil rings and compression rings were inspected. In the Diesel Engine, the cam lobe profile and cylinders were also inspected, while the piston pin bushings, piston pins and cylinder liners of the Gasoline engine were inspected.
The total test duration was eight hours. To accelerate wear, 50 grams of AC Fine Test Dust was added, in slurry form, to the crank case every hour.
Diesel Engine wear tests were performed using filters with high efficiency ratings for particle sizes: 40 Microns, 8. 5 Microns and 7 Microns.
Gasoline Engines wear tests were performed using filters with high efficiency ratings for particle sizes of the following sizes: 40 Microns, 30 Microns and 15 Microns.
ANALYSIS
The researchers found clearances in the Diesel and Gasoline Engines varied between 2 and 22 Microns during engine operations. That means particles in the 2 to 22 Micron size range are most likely to damage Engine parts. Particles smaller than 2 Microns will slip through the clearances without damaging bearing surfaces.
CONLUSIONS
The researchers drew the following conclusions:
Abrasive Engine wear can be substantially reduced with an increase in single pass efficiency. Compared to a 40-Micron filter, Engine wear was reduced by 50 percent with 30-Micron filtration. Likewise, wear was reduced by 70 percent with 15-Micron filtration.
Controlling the abrasive contaminants in the range of 2 to 22 Microns in the lube oil is necessary for controlling Engine wear, and “The Micron rating of a filter as established in a single pass efficiency type test, does an excellent job indicating the filter’s ability to remove abrasive particles in the Engine lube oil system.
The smallest particles most popular “full Flow” filters capture with high efficiency are sized 25 to 40 Microns, depending on the filter brand.
BYPASS FILTRATION
You might look at a by-pass filter as an addition to your engine’s security system. Your regular oil filter passes the full flow of oil from the pump and removes particles bigger than about 20 to 30 microns. Left in the oil, particles smaller than this size can contribute to ring, liner and bearing wear. These same particles can also contribute to engine deposits, which can hurt engine performance and induce oil consumption.
If the regular “full-flow” filter were designed to filter smaller particles, there would be a risk of insufficient oil flow through the engine as particles accumulated in the filtering media of the full-flow filter element. In fact, regular filters come equipped with a “relief” valve, to allow some of the oil to by-pass them completely. These valves insure the proper flow of oil is maintained to protect the engine, even if the filter media accumulates enough material to cause excessive pressure drop across the filter, or the oil is too thick to pass through it fast enough.
By-pass filters are an addition to the regular oil filter. They take only a portion of the oil pump’s flow, and can therefore be more efficient in removing even smaller particles than 5 microns. Eventually, all of the oil gets circulated through the by-pass element. Removing particles smaller than 20 microns is another step in reducing the risk of engine wear, and can also help in reducing risk of oil viscosity increase.
A side benefit of a by-pass filter is that it usually increases the amount of oil necessary to fill the engine oil system. More oil means contaminants are less concentrated and likely to cause harm to the engine. More oil also means more additives are available to neutralize contaminants and protect vital engine parts.
By-pass oil filters can add to your line of defense against engine wear and deposits, helping maintain engine performance and long engine life. When it comes to providing you with security for your engine, a high quality filtering system goes along way.
Hope this helps,
Wayne
amsoilman
