I just had a new lift pump installed today under warrantee, (57K miles) and I want to pick up a pusher this week and install it while the lift pump is still new. My question is, which Pump is more suited for my needs? Carter P4601HP with 15psi @100gpm or the Carter P4600HP with 8 psi and I believe 70gpm. My new lift pump gives me 15 psi now so I would imagine the P4601HP would be the logical choice. However, I read here that a lot of the guys use the lower 8 psi P4600HP. I'm at a loss as to why a lower psi pusher. I will be running it off a relay. Thanks for any help resolving this issue for me.
Kevin
Kevin
