Which stock turbo would be the best?
Black Tube on side of the engine
Smarty, And Engine Stumble Question.
Well I've run short of money to finish my excursion swap as originally planned (thanks to sled pulling with my 01 :-laf). Anyways, I've decided to sell my SPS62 turbo and downpipe and use a stock turbo to recoup some money. For all of you 3rd gen guys, which stock turbo is the best (most airflow) and will work on my 04 cummins engine.
I seem to remember maybe the 04. 5+ turbo's were slightly bigger than the 03-04's? Were they different based upon a manual or auto trans? Are all the turbo's from 04. 5+ to 06 the same?
Either way I will be putting a boost elbow on, so the electronic wastegate will go in the trash. No problems there.
Thanks,
Jesse
I don't know if this is accurate or not but I think that an 04 with an auto came with a HE341W. 04. 5 and 05 manual came with an HE351W, don't know about the rest?
Are all 04. 5 and newer an HE351W or did the auto's come with something smaller on the exhaust side?
04. 5 and up did have better turbo's than the 03-04's did.
03-04 would make 26-30lbs of boost
04. 5 and up will make 32-40+ of boost
I have my stock turbo that I removed from my 03 at 10K, put on a SPS62. Since then I have traded for a Silver62, wish I had a SPS62 back on my truck, better for towing.
Maybe some kind of swap in the making?
Can you expand on this a bit? I'm needing a turbo for my truck and was planning on going with the Silver 62. Why did you like your SPS62 better then the Silver62?
Thanks,
Carl
