On Y2K trucks there are 2 fuel pressure test port fittings -The Inlet-protruding from the back of the fuel filter, and the Outlet- protruding from the injection pump next to the overflow valve. Which source would be the best location for the pressure gague? It seem to me that the outlet would give the most accurate readings as any restriction from the fuel filter would be included in the final pressure readings. Could you remove the shrader valve, screw on a 4AN Hose barb fitting and run a hose to a remote sending unit with a 1/8NPT hose barb fitting? Is this too simple? Am I missing anything?
2000 Qc LWB ETC 6Sp 3:54 LSD, + all the options except leather, BD Stage ll Injectors,Edge EZ, Psychotty& K&N,
BD E-Brake with Shifter Control, ISSPRO EGT and Boost Gauges, Transfer Flow 50 Gal. Alum. Fuel Tank, Line X
16K Hijacker Double Rocker, Pulling a 35Ft. triple slide Spinnaker 5vr.
1996 Viper GTS
Suzuki DRZ400
1100 Yamaha Cruiser
[This message has been edited by TomB (edited 05-12-2001). ]
1996 Viper GTS
Suzuki DRZ400
1100 Yamaha Cruiser
