Toyo mt
I just mounted a set of the Toyo mt's, Lt 295/70/17 and I like them so far. Very quiet, look good and the spare fits under the bed. No info yet on the wear. One thing to keep in mind The Toyo is rated at 3970lbs/tire at 80psi and the Procomp is rated at 3195 at 65psi max. I don't know if you have the dreaded TPMS system but if you do, you will have to use the light load setting with the Procomps and wont be able to lower the pressure too much below 60psi in the front or you will get a warning light and chiming. The procomps are 13 lbs lighter, less unsprung weight which is easier on the suspension but my vote is go with the Toyos.
