Hey Guys ,
This information that dieselnerd posted is actually fairly accurate.
What you see here is 2 trucks stalling out here at 2100rpms,
While i do not advocate stall tests unless you know what you are doing and what the concequences are , the information provided by Dieselnerd is actually very useful .
Ok, by his own words Dieselnerd's own truck stalls out at 2100rpms, the testing I have done with milled stators and 230 hp trucks show the tc stalls out at approx. 2200 rpms, so he is close , similar to the Suncoast , Dunrite, BD, Protorque, test results.
However the truck stefan is talking at makes 400 hp,measured WITHOUT LOCK UP< its actually a little more, for arguement sake lets sake 400hp.
This 400hp truck stalls out at 2100 rpms, what does that tell you.
If you were to take Dieselnerds same converter and put in my truck it would stall out well past 2800rpms, i would say it would be around 3100 rpms. Remember he has about 600 ft lbs of torque, we have about 1200 ft lbs of torque.
Because the higher the hp, the higher the stall.
Putting a milled stator in a first generation truck that has no lock up will actually be pretty much useless.
Since we can infer from Dieselnerds post that his stall speed is 2100 with 230hp, with lock up, we know that without lock up it will be about 185hp.
Remember the dyno testing done on the tst plates is done with the tc locked up.
Since 1st generation trucks dont have lock up, if they are dynoing at 210 or 220 they are actually making more power than Dieselnerd, because when they dyno test their horse power is actually being measured in fluid coupling.
Now , if you take a 230 hp, first generation truck and install the a milled stator tc like Dieselnerds, the 2100 stall speed that he was getting now becomes a 2400 stall speed making it useless to guy with a first generation truck that has no lock up to fall back on.
2400 stall in a first generation truck says it all, its way past your peak torque.
