Which turbo would you suggest for a single charger application on an 03 Ho with pmcr,fass,afe intake,4 inch exhaust. And has anyone tried the Snow performance water injection? How does it work? what chances of blowing something up do i have.
ttreibel said:If you go to twins and a TST box you can get over 500 RWHP with stock injectors and 48RE tranni. You will need bigger injectors to go higher and from what I have seen it seems the rail on the common rail runs dry at about 580 RWHP. The watter injection still is being worked out on the 2nd gens I would forget about it for awhile on the 3rd gens.
Save your money for twins they are the only way to go! Don't believe me just go to one diesel drag you will see the light. .![]()
nickleinonen said:there is rumors over on the DTR about a turbo from ats which is VGT... suppose to be replacing the aurora series ther have/had
vgt would be great except they are crazyloud with a free-flowing exhaust
nickleinonen said:i don't see a problem with that :-laf
RDietze said:have you heard the ford's with the vgt? i appreciate the sound of a legacy turbocharger, however, the vgts sound more like dental drills. we shall see if it even sees fruition.
