Matthug said:When towing you want the smaller housing because there will be more boost present which means lower EGT's. Faster spoolup is also nicer when towing, less smoke too.
KHelfrich said:what is the advantage of the 62/14 it has lower drive pressure and spools slower i thought the lower drive pressure is good cause it lowers egt but is the 12 has lower egt why would you want the 14
one last thing when running twins dont you want both housings to be big so all the exhaust from 60 lbs of boost can flow easily or do you need a small primary to achive the high boost pressures
KHelfrich said:zstroken
so your saying get the 62/12 now and it will have the internal wastgates and then when i go to twins add an external wastgate in the manifold then i will have internal and exturnal wastgates
ken
