Which type brake controller?
Best route?
West LA or East TX?
Prodigy's on E-Bay
Do a search on EBay. The Prodigy's can be had for about $100.
I have one and it works better than anything else I have ever used. Towing a 25' Holiday Rambler Alumascape Travel Trailer. Without going out to the truck and measuring it, I would guess it's dimensions 3"W x 5"D x 1. 25"H
Good Luck,
Frank Dz
fallbrookjeff
Do a search under my name in the Towing and Hauling forum. I reported on both the Jordan and the Prodigy.
Tagalong
Thanks BigMike but I did one better. Wife found 2002 Camping world catalog and President's club price $116. 10 plus choice of $1. 00 shipping or 10% off. Yes I ordered it today. Did not order the harness. What's wrong with splicing into cable DC supplied? That's the way my Voyager is installed. Does the Prodigy have any connector on cable or is it just wire ends? If it has a connector and harness plugs into Ram and other end plugs into Prodigy, I need to order harness.
Thanks,
Paul
Paul,
The Prodigy comes with a wire harness that has a connector on one end that plugs into the Prodigy and loose wires on the other end that you can wire into the Dodge supplied harness. If you don't have the Dodge harness, you can buy a Tekonsha harness from Camping World for $10. 99 -- it has the Dodge connector on one end and the Prodigy connector on the other end and therefor no splicing required; if you are using it for a controller other than Prodigy, the instructions with the connector tell you to cut the Prodigy connector off which leaves you with a harness just like the Dodge supplied harness.
