As I mentioned in my earlier post, I would need to know the physical lengths of both types of antennas you are proposing... physical length of the antenna is the primary performance detail one must consider with antennas. The longer the conducting length the better (to a point..... )
Sorry guys, I hope I can clarify some antenna misconceptions:
(sorry it's long)
Remember that when dealing with antennas- they are radio frequency wave radiating devices. All frequencies have a "wavelength" - For citizens band radio, this wavelenth is roughly 11 meters long or roughly 35 feet or so. Now, for practicality purposes, it is not standard to build antennas 1 wavlength (35 feet) long or bigger. The sheer physical size gets to be too much to hold in the air!!
Without getting overly technical , antenna efficiency starts out at next to nothing (basically nothing radiated) for antennas of . 001 wavelengths long (as expected since this would be a very short antenna indeed!!) and increases very rapidly as antenna length is increased TO A POINT at roughly . 25 wavelengths, at which is the point of diminishing returns (efficiency chart flattens out!).
So what does this techno-stuff all mean? It means that as you DECREASE antenna size DOWN in length from the . 25 wavelength magic number, your performance goes down FAST!!! It is an extremely steep curve, believe me!!
NOW... for the CB band, . 25 wavelengths is roughly 2. 76 meters, (whatever that is in feet) long. Sooo. . this would be a REALLY nice length to use... ... . but too big for many folks liking!!
What I am getting at here, is the SHORTER you make it, performance will degrade significantly. If you want to be reaching out as far as you can with every transmission, you are gonna need an antenna about 8 or 9 feet long!!!
SECONDLY... ... there is yet ANOTHER performance robber at work. As we make antennas shorter, their feedpoint impedance drops from the nominal 50 ohms down quite far , around 5 or 6 ohms for short antennas. In order to make your CB radio transmitter happy (since it likes to "see" a 50 ohm load), the antenna is what we called "loaded" - that is, a loading coil placed at the bottom of the antenna most often. This little coil makes your antenna look like a perfect 50 ohms to your radio, but guess where most of your transmitted power goes??? You got it, disipated as nothing but HEAT in the coil - no radiating quality to speak of!!! Only 10% of it will actually make it to the "whip" part for actual radiating!!!!!
The next little bit regards what we call "ground losses". A vertical antenna , in order to radiate efficiently, needs a ground "plane" area 360 degrees around the base of the antenna. Deviating from this golden rule will yet further reduce radiation efficiency!
I know, I know, you are all thinking, what is the point of all this, right???
This is the point- if you simply want the BEST mobile antenna system you can have, a full size quarter wave (long) vertical antenna mounted smack dab in the middle of a big flat metal are will give the best results- period. There are NO loading coils in this system, it is close to 50 ohms, and all is well... ...
Soooooo... the bottom line is, when you are looking at antenna systems, the longer the better. Mounted such that it has a 360 degree area of metal around it is better.
The more you deviate from this, the worse it will perform! And the degredation is pretty huge!!
So when buying your antennas, ask the salesman how long the antenna is in terms of wavelength, and if it's in the order of . 09 wavelengths, you can expect what you get - terrible performance!
It's unfortunately just the laws of phyics at work here, and there are NO shortcuts to them, or magic tricks - no matter what any mfg may advertise! So don't believe everything you read about CB antenna advertising!!
Ok, I'm gonna shut up now before I have a convoy of Rammers kicking this geek rammer outa here
I'd be happy to answer any questions privately too.
at lightfol@cadvision.com.
Oh yeah, and if you get a ham license, you will NEVER go back to CB ... ... . !!!
Shawn
VE6PV
'99 2500 ISB QC 4x4 5spd SB, Camper Special, Tow package, Intense Blue, Armourthane color matched box liner. AND I LOVE THIS TRUCK!!!
